SignUp Now!Originally posted by jsta6
Hmm.
I have a TE44, intercooler and 1/2, THDP, cold air kit, no cat, no mufflers, and 2800 stall converter. 93 octane.
I run 22lbs of boost.
I don't start to get knock until around 17lbs.
However, the best "spray on" point that I cound find is not 15lbs, 12lbs, or even 10lbs, but 7 lbs.
So, if I go WOT, and I shoot up to 22lbs, the pump will be spraying just as much at 7lbs as it will be at 22lbs. Of course, this is assuming the pump is quick enough to get the alchy there in time. It may start at 7lbs, but it may not get there until 12 or 15? Right?
But, if I do NOT go full WOT, if I am just 75% throttle, and lets say I am just cruising at 7-10lbs of boost, my kit will be spraying 100% speed, when I don't need it to be.
Wont this effect my tuning/O2's, etc?
TIA!
Steve, any comments?Hmm.
TIA!
Originally posted by 1badTTA
But what I am suggesting is to basicaly Hotwire the pump speed potentiometer when the second switch is activated. I don't know it the pump speed runs on +12v or ground, but it must be one or the other and simplying whichever to the other side of the pot will make it think it is all the way at 100% and the pump follows. Understand?
Originally posted by Razor
Set the Hobbs to 20.. but the kit is designed for only 20![]()
No more comments from me![]()
