anyone using this from turbotweak?
Looks like a nice simple product that WORKS..... this will be my next wideband. Go to Eric's support board and look around for information/comments on this product.
Chuck
Chuck
I did......sounds nice I'm sure I'll go with it.....was just looking for a few other opinions......
Go with the 6.0 wide band chip and power logger with an lc-1 wide band with xd-16 gauge and you won;t be dissapointed.
That unit is quite nice too, you can;t go wrong.
bump
just about ready to order........ just figured I'd bump the thread to the top to see if anyone is using one. Comments?
If you like the gauge on your dash go ahead and order it. If you want something thats going to look ugly but the sensor is more expensive and lasts longer go with the ngk afx wide band. Depends how much leaded fuel you intend to run basically.
Im running the AEM Wideband ,but I do not have the gauge. I use the Scanmaster and have a Powerlogger. The AEM stuff is really nice, and if Eric likes it...you know it works. It makes it real nice that his store has all these components now. I got my 6.0 Chip, 80#inj, Powerlogger, AEM wideband, and Scanmaster upgrade chip...all shipped together. The only thing I wasnt able to get was the wiring harness to hook a transducer to my ALKY system to log my pump statis during a run. Had to get that from Julio.
:biggrin:
I use it. Simple and effective. I had a bad exp with the LC-1 but it was purchased used. Worked fine at first then the issues came. Most just use the logging feature and hide the gauge.
Nothing wrong with the AEM unit, its just the bosch sensor life is less than the NTK under the same conditions, due to sensor design.
