Can't really tell you why the directs burned. A lot of things could cause it. Low line pressure, wrong clutch pack clearance (too tight or too loose), bad seals and the list goes on. If your going to dual feed your going to need the maximum number of springs (16). I actually use stronger springs than stock when dual feeding. It helps prevent the 2-3 shift bind which has been a common issue when dual feeding.
