Everything BUT the ESC module is used on non-turbos.
MAP- The most common car to get one from would be the 96-03 SuperCharged Park Ave and Bonneville. Used on some other cars so the easy thing to do is to match it up with an old part. The electrical connectors are different so if it wont plug in than it isn't the same.
FP Relay- Same as 86-87 Park Ave,Electra,Century,Olds with the 3.8 SFI motors.
AC Comp Relay- Common relay used for everything. Again match it up or compare the part number if it is still there.
