arp head studs with the allen in the end?
1320
PHD of Hotrods
I ve seen them for others.....I think ls1.....but has anyone seen them with the allen in the end for TR's or better yet a TTA since the head bolt/stud lenght is different?
It makes so you can install them with the head on, so you don t need the clearance above the studs to pull/install.
set the head then install the studs using the allen in the end of the stud.
Any part numbers?
How about ARP studs for M@A heads? have those? 12 point with allen head screw !
