TurboTnZ06
Go on red!
- May 7, 2002
Bought it new for $130.
Yours for $50 + shipping from zip 80437. Comes with allen head bolts to bolt to tranny, washers, and drain plug.
Fits 2004R BRF transmissions. Used it for a few months only. No track use. It is heavy duty and should strengthen the tranny more so than the stock flimsy shallow pan. It has the cooling fins on the underside as well. No scratches and is excellent condition. Had the pedestals in the pan shaved off so I could run a taller filter. I then switched to the almighty PTS Extreme Custom Pan that requires 257 quarts to fill up.
Email me if you have any questions or concerns:
jim at blix dot net
Thanks!
jim at blix dot net
Thanks!
