monteperformanc
- Jan 15, 2009
Do you mean the puck or the actuator? Where should I look?
Make sure the hole is coveredDo you mean the puck or the actuator? Where should I look?
If they aren't spinning the tire isn't the problem...Leave harder or look for ways to make it spool faster
The key here is he is using stock suspension, it will not be easy to hook em as all Tsa racers are fighting this. I run 16 psi and will blow them off if foot braking as it preloads the suspension. If using trans brake and shocking the suspension I can get 1.51 60 foots. Talk to any Tsa racer to verify, but suspension is the problem when stock.
By the way I run a 2300 @ 0-1 psi converter and foot braking does not work, a looser converter will help but coupling rpm will also change.
Flashing converter, more stall, leaving harder or trans brake will all help, so will proper suspension.
Good luck
Bill
Tsa Rra
My MT street radials are at 26 psi and stick like crazy on the street.
Are the tires spinning at 0-5 psi when leaving the line?
If so, my guess is your converter is too tight, if not you need to leave with more boost.
Okay I will check that.
Have Dave get your converter re-stalled as you want at least 2800 stall, been down this road many times as most owners are afraid of too much stall?
My race car has an 8" converter with 4500-5000 stall, and is actually not bad on the street with a 70mm turbo!
My general rule is any converter to be matched to the turbo must have at least 2800 stall at 0 boost, but I like to see 3000 or a little more for a performance build.
My original 9k mile T has a 10" non-lock up that was installed in 1987, and I only have ~100 RPM less at 65 MPH over a stock converter/turbo.
If his tires are spinning at 0-5 psi boost launch, his converter is too tight? You mean loose, right?
I got back to the track this weekend and while slightly better, I still wonder if there is something wrong with my combo or tune. My last (best) run, I was able to get up to 12 psi on the foot brake. I went 1.80 60', and a 12.41 at 108. This was at 26 psi max boost and I got 6.3 kr probably because I had bumped wot timing .7 deg on that run. My other runs were like 109/110 mph with a 12.50 et. Shifting at 4900. Converter locked in 3rd gear. Am I wrong to expect more out of a 5957 or do I just need to turn up the boost and try to launch at a higher boost too? It's almost to the point of pushing thru the line.
Stock heads/cam/IC/air intake/downpipe/ported elbow
No cat, 2.5" cat-back
12" lockup converter 2200@0
E85
1/8 mile was 7.93 at 87.9
What do you mean downpipe. As in stock down pipe, or down pipe is one of your mods? You sure you should be locking up that converter on a wot blast? You sure that converter doesn't suck in the areas of coupling? a 12 psi launch is pretty dam good. How was the vht situation? Are you spinning your rims inside your tires? That kr hurt you really good too I bet. What springs do you have in the rear? Do you have air bags? What about sway bars?
I know I know the stock intercooler and down pipe have been in the 8's. That's great. Now that that's out of the way, get a dutt neck on that intercooler, a new down pipe, better converter (I know that thing is slipping) (don't lock your converter either) and get a thicker rear sway. And/or yank your front sway for the track. It's easy with a stock intercooler.
Also, a wideband for seeing your air fuel ratios would be nice. Or a power logger to see what's happening when you cross the traps. Do you have stock valve springs? Have you had your stock cam checked for wear? Yank that timing until you get no KR thru the entire run.
If you want to do it on the cheap, port your factory intercooler's inlet tube so that's it's radiused, and buy a Kirbans 3" down pipe. They're cheaper. Also, what mufflers are you running in that car?
