I'm starting to wonder if I am worrying so much about my oil for nothing..After being completely heat soaked, it reads 5psi, and I believe it's a mechanical guage. I have the GNX dash with VDO guages in it. It shows 80 on cold startup and my pressure throughout the RPM range is fine, but it's just sitting hot idling at a light that worries me. I just installed a new thrust plate and the blue spring on the oil pump, and that helped on the higher end, but not at idle. I'm thinking of going to 5w50. I have been running 10w40 Castrol Syntec. Any suggestions? I've not once seen the oil light come on even if the guage reads slightly less than 5psi so I'm wondering if it's off....any advice or input is greatly appreciated
