DonnieShort
Who's Next?
- May 27, 2001
Where to start?.....
Firstly, Fp set to 43-44# line off, T+ set properly on, on, off, off, base setting to 3½"maf 0 normal idle. Doesn't change but a point or two down when putting it on rich idle, but goes up quick when set to lean idle. Vacuum is 17 at ilde.
Over the last few weeks I've been trying to troubleshoot a high blm problem. Usually they are well within range 132-136. But over the last couple of weeks they have jumped dramaticly, to the tune of pegged at 160 at idle
Things I've already done:
I went by Razor's procedure and started off by eliminating the vacuum portion by putting flat gasket material under the vac. pod closing off vac. to everything. It still was at 160. Went around the engine with 2 cans of carb spray around all the usual places tb, plenum intake etc. nothing. I put the maf directly to the tb eliminating the intake tract, ic, turbo etc. that checked out fine, no changes yet still at 160. Ran a can of Top Engine cleaner through it and it looked like I had a little smoke from the ds header ( ATR piece that's been welded 5 different times over the last 6 years ) so I put on a new gasket, Felpro 1400 replacing a copper gasket and still nothing. Turned out to be oil smoke where the valve cover bolts had worked loose and leaked down on the flange. Changed the oil and filter put in a new o2 and that helped a little but it eventually it creeps back up 160. Put in a new fuel filter, still no change. I ran a compression test for the heck of it and it looked like this:
#1 - 145
#2 - 149
#3 - 145
#4 - 145
#5 - 150
#6 - 145
Pretty good for a 113,000+ mile car
So with all that being said, where do I go from here? What is the most logical thing to do next? I do have some Turbo Link files that I can share if anyone would like to look at them. One is a 15 mile or so trip back to the house and 2 more are some idleing and staging it up some in the driveway. Please help!!!
#1 - 145
#2 - 149
#3 - 145
#4 - 145
#5 - 150
#6 - 145
