ATI th400 convertor
jpwalt1987
ATI Torque convertor for TH-400 transmission, standard install height. Stall in the 3300 range at 0psi and 4500 at 8psi.
This convertor has been 9.21@148. It was on a 274" S2 GN-1 headed car using a T-brake that weighed 3450lbs.
$550 plus shipping
I see people going to a TH400 all the time, someones gotta need a convertor. I am going back to the TH2004r because I miss my overdrive. I hope the convertor I get for the 200 is as good as this one is. This is a BAD@$$ convertor. :D
BTW, my TH400 will be for sale as soon as I get under the car and pull it out.
I had this convertor behind a 109 TSM style build with a 224/224 cam and a pt70 turbo with GN1 heads. It was right on the money as far as stall to get the turbo spooled up and the slippage up top was under 8% roughly. At 140 mph I was at about 6200 rpm(This was a little longer than a 1/4 mile run) with 3.42 gears and 275/60s.:biggrin:
