Atr Carr converter ?
turbocam
What size bolt does it take?I have bought a few different sizes and they will turn about one and a half turns and bind up.:mad:Does anybody know the correct size?Its an N stall for a th350,I can get the number if it matters.The stock gn bolts do the same as above.Thanks.............................
you cant put metric threaded bolts in a converter designed for sae std thread bolts
i cant explain it any simpler
i cant explain it any simpler[/QUOTE]
Does anybody know the correct bolt size?I bought std. bolts,thanks.......
Thanks,the only number listed on my receipt was 3/8 - 18.I will try to find the 16s.Thanks alot....................:biggrin:
they will either be fine thread or coarse
coarse should be 3/8 -16 ... try a header bolt on the threads , they are 3/8-16 pitch if it fits you know what you need
if they look like fine thread theres 3/8-24 converter bolts
heres summits list
Torque Converter Fasteners - SummitRacing.com
