ATR Crossflow Exhaust Install Problem
gn_john
Install new ATR Crossflow exhaust system and the front pipe is hitting the floor. Can not seem to get it to not hit the floor. Has any one had this problem and what did you do to solve it . Atr said I need to readjust it.
OOOOHHHH Boy ,I have been in you shoes. Rattle, Rattle, Rattle.
It is a FREAKIN pain bro..I know.
I have this system on my car now and love the sound and performance. Today it set a few alarms off in a parking garage as I was driving through :) .
Here is what I done w/ mine, ran the system for a while to let it settle out.
If it was like mine it is only tapping/rubbing in 1 small area and it does not need much.
Get back under the car and loosen the clamp on the connection between the cat and muffler. Leave the over the axle pipe to muff clamp on the muffler tight and only manipulate the one by the trans tunnel.
Try push/pulling and twisting the pipe connection I spoke of to get a little room. If you get room by manipulation then keep it held,twisted, etc in that spot an lock that clamp back down this may require another person to hold pressure/whatever while u tighten the clamp back.
Also, look at the exh hanger coming off the trans mount over to the cat and see if the rubber is pulled tight keeping the pipe up.
If so get a prybar and bend it down a little(don't get crazy) just some and see.
Another place is where the muffler mounts too the body.
U can put some sort of spacer between it and the body to give you a little room.
It takes time but just fiddle around with the above mention things and you will get it.
Did your pass side pipe coming out the muffler reach the hole in the frame?
Mine was short a few inches short, so I used one of the rubber hanger pieces that came with the system drilled 2 holes in the rubber strip and used that to bridge the gap from the hole to the pipe. And you can not even tell at all.
The pipe hitting the floorpan and that pass pipe being to short for the hanger was my only real problems.
The Pipe tips polish up nice with some effort and really gleam.
Good luck, let me know if it works.
Thanks for the tip I will try it tomorrow . I love the sound of this system accept for the rattles.
What did you use to polish the tail pipes?
i use mothers mag wheel polish for stainless steel-
it comes in a small round dish at the auto parts store and with some rubbing, the stainless will be bright and shiney
HTH
BW
I picked up this metal polish at a big car Meet a year or so ago. But, can not remember what the name of it is...it is awesome though.
The wadding polishes like never-dull, etc. Or the mothers stuff will work.
I have the system, and it did the same thing on my car too. I did what nasty said and it fixed my problem in the past..you should have good results too. My car's only go 7k on it, so theres no sagging motor mounts or springs etc...every car is different I've come to the conclusion. There is no one size fits all.
I had the system on my 86 GN w/90k and it fit fine..no fussing or nothing.
I had the system all adjusted..then last wk I put a torque strap on my car..bang bang bang...it changed the angle of the motor by picking up on the passengers side..gotta go re adjust again! LOL
