87-TURBO-T
- Apr 16, 2009
I have a ATR down pipe with the atr external gate. I have the adjuster almost all the way in, and can only get 16-17# of boost. how much can you get with these? thanks
SignUp Now!I have a ATR down pipe with the atr external gate. I have the adjuster almost all the way in, and can only get 16-17# of boost. how much can you get with these? thanks
You may want to take the wastegate apart and check to make sure everything is in proper working order. I had the ATR set up and it did not hold up very well. The bushing bascially disappeared and the gate ended up have problems similar to what you have. The ATR gates weren't too dependable and I am amazed that there are still some out there. Mine lastest about 10K miles on an almost daily driver back in the 90's before it went south. Limit Engineering used to modify them and made them work pretty well but as far as I know no ones deals with them any more. A Tial 38MM bolts right up to the downpipe and is reasonably priced and there are other gates that bolt as well.
what gates will bolt right in?
i have replacement springs (4 sizes) and diaphragms for these units if you need them--------i have them on several of my cars that have been on since the mid 90's and really don't have much trouble with them-------if you need help give me a call--------Richard 336-684-3653
