- May 28, 2001
or, the lack of, can get you in big trouble...BTDT.
While I was replacing the ft calipers, pads, and adding the hb, there was a "BS session" going on w/ several other car guys.
When I put the pass caliper on, the lower bolt went beside the caliper brkt instead of thru it. [Besides listening to the BS, I was sitting in a position that required me to work by feel.] BAD CHOICE!
I have driven the 55 for some 200 mi since the install. Yesterday it came to a screeching halt. [Literally].
The caliper rotated up, got jammed into the upper a arm, locking the brakes.
Fortunately, I was a mi from home. I got a ride, got the trlr, and retrieved the heap.
1 bent pin, 1 set of pads, and some labor....GTG.
BOTTOM LINE: PAY ATTENTION, and double check your work! You may not be as lucky as I was...
John Wayne was right!
