Austin Area - Newbie to GN but not Buicks
Well Looks like I am on my own. I got a new DW 300 pump, Hotwire Kit, Vacuum Booster and Master Cylinder. This will help me get the repairs that are needed sorted out.[/QUOTE
You will also need the brake pedal from the vac brake car.
Actually the powermaster is working fine for now. I had to learn how to properly bleed the system. Once I did that I am good. I will eventually replace the powermaster with a vacuum system. I will need to go to the local pickapart to get the pedal, pin and retainer clip.
Update: Found the issue with the GN. I have a bad MAF. I unplugged the MAF....and the car stays running!
