Auto Dimming Compass/Temp Mirror FS
Monte_ExpreSS
I have one more of these available. It is th dual display auto dim with compass & temp display. Included in the sale is the mirror, wiring harness with enough wire to splice, wiring harness cover trim, & temperature sender.
The mirror has been tested & works perfectly. All wiring will come labeled for a easy 4 wire hook up, 1 power, 1 ground, & 2 go to the temp sender. That's it, it's that easy.
$75 shipped in the USA or Canada I accept paypal
[/quote]
Everything is built into the mirror except for the temp sender that needs to be mounted outside the car somewhere
There are also available at the Used Parts SuperStore.
Usually one near you.
I have another one of these available, however it is compass only. Looks exactly the same as the one abve, but without the temp function. Lets do $60 shipped on that one.
Another compass & temp available. This one has the small black spot on the glass (pictured) if the care had airbags. Nothing to worry about though as it has to be wired in to function. Will do $70 shipped.
& Also pics of the compass only auto dim unit. $60 shipped
