Backfires under 10psi plus boost
cswrench
Got an 85 with an add on IC conversion. 87 ECM and coilpack/module.
90% of the time at 10-12psi boost it will backfire thru the exhaust. If i disconnect the cam sensor, it will pull to 18psi boost and run hard for 2-3 seconds then the engine shuts off!?? We have tried every known fix with no success. Any wild ideas?
Thanks,
Rob
WhiteT78Supra said:
change to new plug wires also ck engine tie down strap
Why the tie down strap?
Please explain, as I am having some similar issues right now.
