- Jun 18, 2001
Gotta sell some stuff.
I picked up a TT GN I had planned to race but have no room for two race cars and my Drag radial car is almost done so something has to go. Another board member is very interested in buying the Twin car as a roller so I am going to be selling motor trans and all the associated Twin turbo parts. I am willing to sell either motor I own the single turbo stock style head motor or the S2 head TT motor so I am going to list both.
Twin turbo Alum TA S2 motor complete $13,500
Right now the TT motor is still in the car and can be driven and heard run. It is a TA alum block, billet crower crank & rods, ross pistons short block. S2 heads with Jesel rockers, titanium intake valves and inconel exhaust valves that are new and not roundy round junk. It is fresh and has not been down the track. The previous owner froze the engine last winter and cracked the block which now has a weld repair that is strictly cosmetic. The block has never had any damage otherwise and is a nice TA alum block. Long block with intake and plenum no TB or injectors, to oil pan with balancer, flexplate and motor mounts.
ATR twin turbo headers with EGT bungs and 3" SS downpipes and ATR billet wastegates. Downpipes go out the stock location and are not run under the engine crossmember. $1800
CAS V3 Twin turbo intercooler with fans and intercooler piping, and intake piping $1200
Twin PTE cast wheel 70 GTQ turbos with T4 housings $1500 or $750 each
XFI/Hartline XIM COP setup with coils wires harness everything needed $900
Rossler TH400 Trans is fresh and ready to go. Includes JW bell along with cast alum pan $2200
Weld Aluma Star rims pair 15x14, old style cleaned polished and ready to go 5x4.75 14" wide with 6" back space. Very nice rims bolt on and go all the hard work is done.
Weld Aluma star 15x10 5x4.75 5" backspace Champion double beadlock ONLY ONE rim other was stolen. You can still buy one new rim and have Champion install the beadlock for less than buying a set. $400.
On Center S2 block stock style TA head motor. This is the short block I have 8.14 with back in 2008. It is fresh and ready to go. Block is on center 4.030 bore with one sleeve and roller cam bearings. Crank is 3.59 LA Kryptonite Billet. Rods are NEW billet 6.300 Crower, Pistons are new DLS spec CP's, Cam is super secret Crane billet roller lol, new Comp solid roller lifters, Heads are DLS TA heads with 2.0/1.60 valves, very trick and many details I will share with new owner, Champion intake, Billet fab oil pan. Parts NOT being sold with this motor are the Belt drive, front drive accessories, oil pump, balancer, flexplate, crank trigger, distributor, alternator, throttle body, injectors.
PTE 4788 Billet wheel T4 NEW never run, its the one on the right the one on the left is a cast wheel H-cover 4788 $2200.
- Ross-Lock™ Pro Tree Trans Brake Reverse Shift
- *248 Gear Set
- H.D. 34 Element Sprag
- Rear Case Thrust Bearing
- Glass Bead, Trim Ears, Prep Case for Racing
- HP Overhaul New Bushings, Seals, Gaskets Clutches
- High Flow HP Filter
- Patented Snap ring Stabilizer
- Special Design M300 Billet Input Shaft
- CNC Modified Forward drum with over sized spline for extra durability with ROSSLER EXCLUSIVE Shaft retainer system to prevent Shaft Movement
- Billet Forward Clutch Hub
- Aircraft Grade Quality 7075-T6, Billet Aluminum High Gear Drum, Eliminates 4.5lbs of Rotating weight From Transmission. Also Prevents Drum Explosion!! For Durability and Safety, With Billet Steel Sleeve to Prevent Premature Sealing Ring Wear In Drum Bore.
- HP HD Clutch Packs
