Bad fuel pump?
hemi
Drove car home , went to start two days later and pump is not priming, has power to tank, has a hot wire kit. Fuse is good and relay is good. I guess pump went bad . I'm gonna drop the tank and pull pump and run direct Power to it . I checked everything else so that's my last resort. Sending unit needed to be replaced anyways . Could it be anything else. ?
Could have lost a ground but you'll never know externally. Drop it and end the wonder. I'm sure you know it's not that hard to do. 15 minutes or less worst case.
Just a thought , did you try putting power to the fuel pump prime wire ( grey single connector just behind the alternator ) to see if the hot wire relay pulls in ?
So I'll drop tank tomorrow any recommended sending units and fuel pumps? I had a walbro pump in car worked good for last seven years. I have a racetronix pump in my ta.
All depends on your current mods & possible future mods . Call Mike @ FullThrottle , and get everything at once .
