screamingbuick
- Jul 29, 2010
I'm having a heck of a time with my 87 GN, it falls on its face when you put any throttle on, it hiccups a lot and will eventually build some boost and take off.
I swapped the TPS and adjusted it about 4 months ago and that appears to be working properly according to the scan master.
I changed the oxygen sensor today and that didn't do anything for it, its still reading rich on the oxygen sensor thru scanmaster.
I took the MAF sensor off and sprayed a whole can of MAF cleaner thru it, that seemed to have helped a little for a run up the street, still hiccuped once or twice though.
Parked it, cleaned the MAF again and it seemed to have went back bad again.
What happens when the MAF goes bad, is this what it does, I hate being just a parts changer.
