Baer Rear Disk Brake-Wheels to mount DR's?
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
I have Baer's "Sport" (e-brake) street rear disk brakes and want to buy some 15" x 10" wide wheels to mount MT DR's. If you have the Baers and 15" wheels, what brand/model are you running? I don't want to buy wheels and they not clear the brakes. Frame rails have been cut.
Hot Air
North Carolina
AR23's fit but I don't think they make them in 10" widths with our bolt spacing.
Anyone tried Weld or Billet Specialties wheels?
Conrad
I don't have any experience with Baer rear brakes. I have Baer 12" brakes up front & had to go with 84/85 GN aluminum wheels to keep the stock appearance (blasted the paint off them). Had to use 5/32" spacers with my original wheels.
Baer brake
I have 12" Baer brakes on the rear of my GN and 15" wheels will NOT clear the caliper. The 16" GTA wheels have adequate clearance. I would be very cautious to assume than any 15" inch wheel will clear the calipers.
Dean
These clear just fine 15 x 8" AR23's.
The stock T wheels will fit also with a 5/32" or so spacer.
They also make a 13" kit that won't fit many if any 15" wheels.
Hot Air
North Carolina
What size are the rotors you have?
