balanced rotating assembly, custom cam, built trans etc.
BuickGNturbo87
Balanced rotating assembly
Diamond forged pistons - .020 over
stock crank - balanced and re-condition - all this goes for $800 obo
stock rods - balanced and recondition
balanced flywheel
custom cam - comp cams - $175 obo
champion gn1 ported intake manifold - $300 obo
built 2004r - $750 obo
drive shaft with beffy u-joints
stall converter - 10" pro torque - 3200rpm - 3400rpm - $600 obo
stock torque converter - lessened up to stall around 2800 - $250 obo
comp. chip for pt 61 turbo and 65lbs injectors - $50
walbro 340 fuel pump - make offer
rear end components
3.73 Richmond ring and pinion
limited slip diff - not sure what kind its been awhile since i put it in
stock 28 spline axles
clean stock 87 heads, 87 stock valve covers
2.5" dual hooker cat back - 275+shipping
any questions please pm me or my cell steve @ 414-364-7004
Original post was december 2007.
If you still have the gn1 intake i will take it. Let me know.
I would like the following
balanced flywheel
Would you consider $700
Thanks Ted Drive Safe
