white-t-type
- Oct 13, 2008
I am doing what I call a basic rebuild on my motor. This will basically include new rings, rod and main bearings, and gasket set, along with a camshaft and timing chain. I also plan to port and polish the heads and intake as well as install new valve springs. Would you guys suggest using ARP bolts in the rods and mains? Is there anything else I should consider doing?
