Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
SignUp Now!Links don’t work..Suplimental Alky injected on a Hot Air set-up
LOTS of threads on this. Here are a few to start you out.
http://turbobuick.com/forums/threads/razor.204243/
http://turbobuick.com/forums/threads/where-injecto-alky-hot-air-car.293888/
http://turbobuick.com/forums/threads/hot-air-alky-cooling-data.294894/
Oh awesome thanks for updating me on that! I’m not exactly a whiz kid when it comes forums.@ShaunKris, if links in old threads give you the "OOPS" error here on the forum, copy the link into your web browser's search bar and do a "google" search. the search results will get you to the actual link.
a lot of links posted in old threads no longer work due to turbobuick.com server replacements and/or updates over the years. there was just one in the last year or so.
Boom! PerfectYou can also just remove the "forums" directory from the link to make it work. I like to open the link in a new tab, wait until the "oops" comes up, go to the address bar and remove the "forums" and then hit enter. Looks like as follows:
https://turbobuick.com/threads/razor.204243/
https://turbobuick.com/threads/where-to-injecto-alky-on-hot-air-car.293888/
https://turbobuick.com/threads/hot-air-alky-cooling-data.294894/
I have the GN1PERFORMANCE adjustable wastegate actuator and boost controller for my 85. I was told it would replace the factory boost controller and wastegate actuator. Can you help me with hooking up the boost controllerKirban Performance sells the single hose waste gate actuator. It is listed for an 86/87. It fits the hot air cars with some simple install changes. I am running this actuator on my car with zero operational issues. The only downside to this actuator is that it will rub on the hood insulator. If you go this route I can send you the modified install instructions. Take-care- Brad
The site was basically hijacked / held hostage from what I understand. it has been recovered but the picture links are mostly gone now.Why do the links go bad in these threads. Where is a good diagram of the throttle body vacuum block. Can work on replacing all the links on the first post in this thread? i couldn't get any of them to work.
Thanks in advance.
Does this Help ?Why do the links go bad in these threads. Where is a good diagram of the throttle body vacuum block. Can work on replacing all the links on the first post in this thread? i couldn't get any of them to work.
Thanks in advance.
That is perfect. Thank you. Where did you find that. I didn't see it on my factory service manuals.Does this Help ?
Lol. Haven't seen that in a long time. That shroud is in a box on a shelf.Its also on your radiator shroudView attachment 368949
