Basic question about changing coil pack
QuickWE4
Fuggedaboudit.
Hey folks:
Very basic question here:
I noticed some corrosion on my coil pack when I changed my wires and plugs recently, so I'm going to swap out the coil pack for good measure. I already have a new coil pack and the gasket that goes under it - I'm assuming it's pretty much just a matter of unbolting the old and installing the new? Any tips or tricks I need to be aware of beforehand?
TIA
Rich
just note what color wires goes to what terminals on the underside of the coil when you begin to remove the coil from the module. Write the colors down and then it is easy.
Your plug boots probably have rust in them too, then...the coil is probably okay..just needs cleaning off and use some dielectric grease to keep the moisture out in the future.
