turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
I have recently had my stock alt crap out on me so I ordered the 200 amp upgrade kit. Also recommended was a new positive cable from Caspers. That thing is $90 bucks!!
So, I've decided to make my own. So far I've discovered that the ground and the positive cable to the starter are 4 gauge wire and that the wire to the alt is somehwhere around 8-10 gauge. I'm thinking of running 2 gauge in place of 4 gauge and a 4 gauge in the place of the 8 gauge, plus thicker wires for the ancillary wires attached to this assembly.
What if anything is the benefit of using thicker, newer wire? I'm assuming that there should be a benefit but I could be mistaken. While I'm not building a monster audio system or anything like that, I'd like to be sure that my electronics needs are well insured with the best wiring that I can do.
I only want to do this once...
BTW, I was going to add a switch to the battery so I don't have to keep disconnecting the battery every time I do something under the hood. Will the orange ECM wire be affected at all by splicing additional length to the existing wire?
Any and all advice is appreciated...
