Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
I wanted to post some usefull info (calculations) for the HA crowd am very comfortable with these numbers. By all means, if I missed the boat and you have some time slips that challenge the calculations, post them up. I just picked some arbitrary numbers to show the differences.
The assumptions made are that the car has a good tune, and no other constraints (DP/Header/Exh system, etc.)
A 231CID - HA car at 2.75 PR (23 PSI boost) needs a turbo that supplies:
Stock unported heads - around 36 lb/min @ 5000 RPM
Stock ported heads – around 40 lb/min @ 5000 RPM
Stock unported heads w/alky - around 46 lb/min @ 5000 RPM
Stock ported heads w/alky – around 51 lb/min @ 5000 RPM
If you changed the cam and peaked around 5400 RPM at the same PR the turbo needs to supply;
Stock unported heads - around 39 lb/min
Stock ported heads – around 44 lb/min
Stock unported heads w/alky - around 49 lb/min
Stock ported heads w/alky – around 56 lb/min
What this all means is that a HA car/Alky/Ported heads/Cam/Unlocked converter should be able to run around 11.54@115 at 2.75PR (around 23PSI).
If the set-up is run at 2.38PR (around 18PSI), it should be able to run 11.9X@111 unlocked, or 11.5@115 locked. You will need about 54 lb/min.
A true cold air system that takes the intake air from 130F to 70F seems to be worth 20WHP, and removing the inlet restriction (Grossly estimated the inlet pressure drop) seems to be worth about 15whp or 20F in the charge temps.
There are many who have proven that building an 11 sec HA car can be done.
I want to give credit to my friend John Estill since my calculator it is largely based on the work he has done many years ago.
Remember: The absolute HARDEST thing about building a fast HA car is to believe!
Hope you find this info useful in planning your next move.
