SignUp Now!Yes, battery tenders do work! But DO NOT TRUST the cheap Harbor Freight ones or equivalents. Spend a little more & get a quality unit. We had the unfortunate experience of 3 batteries burning off from overcharge with the cheapos. One battery was salvageable, the other 2 needed replacement.
Batteries are sensitive to many parameters. If managed well, they'll live a long life. If not, their service life & discharge depth drops off quickly.
Battery tender or not, it's a good idea to start a vehicle at minimum once per month & run it for 12-15 minutes. If equipped with A/C (R-12 or R-134A systems alike), run that too for the same period to keep the seals up & oil circulated. Saves having to replace a seized compressor later, and keeps you from leaking out freon.
My Sears battery maintainer/charger never really charged the battery. If I put it on a slightly discharged battery, the charge light stays on and never goes off. If I charge the battery with my Schumacher charger, then the Sears unit will keep it charged (green light stays on).I guess I will need to remove that cheapo and get a battery tender!
I notices that it never says charged. So that means it's always charging.
Good responses, thanks guys.
I like the Battery Minder model 12248 which has a desulphating mode. I have a couple of Optima batteries that are both over six years old and still plenty strong, thanks to the Battery Minder. It is not cheap but it works very good.
The only problem with the 12248 charger is it occasionally switches to gel mode on its own. This has not been a problem for me. The manufacturer says this is due to poor connections but that does not seem to be the case. No big deal.
I always disconnect the battery from the vehicle's electrical system before charging.
http://www.amazon.com/BatteryMINDer-Volt-Amp-Battery-Charger/dp/B000X2B0RW/ref=sr_1_7?ie=UTF8&qid=1379489935&sr=8-7&keywords=battery minder
Make sure to get the temperature probe:
http://www.amazon.com/BatteryMINDer-Volt-Battery-Temperature-Sensor/dp/B001DZNDKK/ref=pd_sim_auto_4
You may find both the charger and temperature probe at a local Northern Tool store.
Paul Lohr
Can't say the same for this one. It charged my battery from 6v to full. Just when it's full it never shuts of. I guess it's ok. As long as it doesn't burn my car up.
No, it is little, like a batterytender. My Schumacher is about the size of a loaf of bread. It has a needle that shows the battery strength. It seems that it gives you more info than the small battery tenders with no needle. Is there anything wrong with charging the battery with the Schumacher and leaving it hooked up, to keep the battery charged?Most likely an oder CFR style, that doesn't have Bulk & Absorb charge modes.
Does it weight like 70 lbs? Then it's a CFR style.
I had one of those too. Ole Bessy.
