E Ticket Ride
- Jun 25, 2008
1987 BUICK TURBO T-TYPE with about 5000 miles since professional full ground up restoration. This car is better than new! The engine has been rebuilt and upgraded. The interior is all new including new headliner, door panels, weather stripping, seat belts etc. You must see this amazing car. The paint job is to die for! The color is 90's Impala SS Dark Cherry Metallic The shine is very deep and bright. Most of the upgrades are as follows:
150.00 Red Armstong 107 chip
450.00 255 50 16 Mickey Thompson ET Drag Radials
995.00 GNX-Trans Am style wheels
359.00 GNX style fender flares
925.00 GNX style gauges
36.00 RJC Racing Biggie oil filter adapter
65.00 RJC Racing Billet aluminium horn ring
65.00 RJC Racing power plate
59.00 RJC Racing boost controller
249.00 RJC Racing Deep sump oil pan
449.00 RJC Racing 7 piece billet aluminum pulley set
995.00 RJC Racing Megacooler IC-325P (polished pipes)
89.00 3" MAF Pipe (polished)
450.00 3" Down pipe
36.95 Engine torque strap
649.00 Pitbull Dual exhaust and test pipe
70.00 Racetronix cooling fan wiring harness
235.00 GBodyParts Dual cooling fans
425.00 Aluminium Radiator
115.00 Billet aluminum fuel pressure regulator
50.00 Walbro heavy-duty fuel pump wiring kit
100.00 Series 2 ignition system
125.00 Volt meter and knock gauge (console mounted)
39.95 Polyurethane body bushings
22.95 Rear upper GNX body bushings
Rebuilt Engine, balanced
Ported Heads
300.00 50# injectors
399.00 SMC Alky Kit
1700.00 Precision PT6265 BB Turbo with ball bearings, billet aluminum impeller, and liquid cooled
900.00 PTC 9" Torque Converter non-lock 3400 stall
1995.00 Extreme Automatics Stage 2 transmission (2004R)
300.00? GNX logo Differential Cover CAN'T FIND THESE ANYMORE
6600.00 Custom Paint 90's Impala SS Dark Cherry Metallic with 2 stage finnish
250.00 Sequential tail lights
75.00 Dark Headlights
200.00 Tinted windows
17.95 Aluminum Coolant cap
25.00 Brake Reservoir polished cover
345.00 Embroidered logo spare tire cover in trunk
215.00 California Car Cover
325.00 Fiberglass 3-piece rear spoiler
190.00 Fiberglass front bumper
190.00 Fiberglass rear bumper
180.00 Red top Optima Battery
125.00 GN1 mini starter
300.00 Aluminum rear drum brakes
46.95 front frame braces
72.95 Rear seat brace
69.00 Drive Shaft loop
THE UPGRADES ALONE TOTAL OVER $22,000.00 NADA guides value is $30000.00 as stock. This car is better than stock and better than new. asking BEST OFFER OVER $20K Show or drive this beauty. Call or text me to make an offer on this work of art! 801-499-7878
