So I changed the valve springs to the PAC 1201 beehives and adjusted the valves. The vacuum came up to 10-11psi at idle rpm of about 900-950. I drove it and the rpm shot up to 6k for the first time. Before changing the valve springs the rpm would never go over 4,900. It only hit 6k for a second and then dropped to like 5,100 or 5,200 and there was a single very quick pop sound as soon as it hit 6k. All of this happened within less than 1/2 of a city block (didn't want to push it with sorry brakes). I will upload a video and post the link here. I have to try bleeding the brakes again since I had to remove the booster to get to the 2 rear valve springs and I only bled the bottom bolts (4 bleeder bolts on each caliper).
After I did that little test run, I went to get pizza (lol) and on the way there the car wouldn't go up to 6k anymore, just 5,100 -5,200 (only tried twice). On my way home, I tried to see how much boost it would hold with the foot brake and it wouldn't hold 1psi. When I left from that traffic light, the exhaust manifold gasket blew...again.... Passenger side #2 cylinder towards the top front of the exhaust port. I've tried different gaskets, even tried doubling up the gaskets on that one side, but always the same results. These last gaskets lasted the longest (remflex). I'm going to change over to studs and see if that fixes the issue. Seems like that top bolt keeps backing out like 1/4th turn and then the gasket goes... I have to wait until Tuesday to get more gaskets, so I'll pick up some studs while I'm out.
I will turn the boost down, put the chip to stock, turn the alky off and see if it has any issues and go from there after I go over the valve adjustment again. That was my first time adjusting valves on a car and I did it by feel. To me, they seemed too tight at 0 lift, so I adjusted them to I could just feel a little restriction when trying to spin the push rods. I adjusted each one at 0 lift. Oh and it only picked up 2.3 knock. The ac compressor bolt backed out a little and the belt tensioner taps it ever so slightly... I have to fix that too...
