I replaced the upper and lower control arm bushings on both sides of the car, along with center link, tie rod ends, ball joints, and any thing else that had a castle nut holding it. Anyway, after putting everything together, I took it for an alignment. Mechanic said pass. side was fine but driver side was way off. They said to bring it to a body shop with a frame machine. I've taken it to two body shops and 3 mechanics to get their opinions. They all seem to agree- have a body shop with a lazer set up where they can measure key points to make sure the frame/control arm were not damaged in an accident. What do you guys think? The body shop charges $200 to hook it up and take measurements. Any additional frame straightening is extra. I could just buy a new lower A arm but that might not fix the problem. I have an appointment with one of the alignment shops that already looked at it once, just to have him look at it again before I spend the $200 (or more) at the body shop. After the body shop does their thing, I would still have to get it aligned.
