So recently driving my car I got on the throttle and as soon as I let off it died. No noise or weird sound just died. Turned back on no problem. Then later it shut off as my foot was in it. Wouldn't start back up. Spark and fuel are perfect.
So i Checked all grounds reset the cam sensor (per caspers cam sensor tool) and couldn't get it in time. Yes I set it at 25* after tdc and no it's not 180* out. Car started and sounded like a tractor WTF! Air back firing through the throttle body then shut off.
So now I'm assuming the Timing chain skipped a tooth or 2. Pull off the front cover and chain looked perfect. At tdc the marks on the gears line up perfectly.
So now I think maybe I wiped the cam flat. Oil is clean so I pull off the intake to take a look no metal shards litters all look normal same swirly mark on the bottom of each lifter. So I turn the motor to see if the lifters are moving up and down (no push rods or rockers on the motor at this point) and I distinctly hear air leaking out of the DS head through #3 intake runners. Take a closer look at the valves /springs and one of #3s is sitting lower then the rest. Don't know if it's bent or broken or fell out of place yet as the head is still on the car but I'm assuming it bent.
What the hell caused this? What steps can be taken to prevent it happened again? What else should be checked out. Ect.
Ps yea I know a simple compression test would have figured this out before I took shuffle apart but it was coming apart anyway as it so happens lol
