Best 1/8th mile To date.
Mr.Spool
4,255
542
113
3455 W/O me in it. Limited with CF5. 3670 with me on this pass.
even more impressive.that has to be up there with some of the fastest unopened 1/8 passes,if you ever run the car the full 1/4 i would be curious to see that slip as well.should go mid 10s maybe faster.
V6POWER
Senior Member
May 24, 2001
2,790
47
48
72
Mebane, NC
Can you provide info on how you get that great 60' time, i.e., slick or drag radial; foot brake, trans brake, or two-step; boost/rpm at launch? Fantastic e.t./mph on stock long block.
Limited T
166
44
28
49
It might be Bowling Green again this year, before I run another 1/4 mile pass. I firmly believe the 6.69 pass would be around a 10.50-.52. The car was picking up almost 24 mph in Bowling Green this past year. We have a 1/4 mile track within 20 minutes of this track, but their prep over the last few years just absolutely sucks!!
  • Like
Reactions: Mr.Spool
Limited T
166
44
28
49
Drag Radials, 275/60/15, MT ET street Radial R's. Launch RPM's 4600-4800, 26-28 lbs boost. Foot Brake only. All of the body bushings have been replaced with Poly bushings. HR Poly drivers engine mount, transmission mounts. southside upper and lower control arms. Wolfe Racecraft anti roll bar, welded in. QA1 single adjustable shocks, set as firm as they go. Wilwood front brakes.
Limited T
166
44
28
49
very impressive. Where in TX are you located? xtreme raceway park is the new place south of Dallas? I heard good things about it.
I live in Godley, about 30 minutes due south of Downtown Fort Worth. Xtreme is the new track south of Dallas. It's a top notch facility.
I have an all Buick Test N Tune day set up for May 11th. We have the track from 10-5.
Come on out.
Limited T
166
44
28
49
I've data logged and tested 3 stock location intercoolers, one was the factory stock, I ran a 6.79 @ 99.8 with it. Other was the GN1, which was on the car for the 6.69 pass and a Precision slic. It had the best numbers of all 3, but for the money difference, I'd save the $400 extra and use the GN1.
I'm waiting on a couple more to test, I'll post the numbers for them once they're in place and I get some track time.
Living in Texas and still using the ac on my car, I'm not a fan of a front mount Intercooler at all!.
  • Like
Reactions: Mr.Spool
Limited T
166
44
28
49
It was a 10.50 quarter mile pass.
This was my best full 1/4 pass in BG last year. Ran a 6.85 @ 100, but blew the up pipe off around 1000’. The formula 1.57 is pretty accurate on my car. Multiply the 1/8 by 1.57.
Rob Ortosky and I are both amazed at the almost 24 mph gain between the 1/8 and 1/4.
  • Like
Reactions: Mr.Spool
V6POWER
Senior Member
May 24, 2001
2,790
47
48
72
Mebane, NC
Thanks. Simple combo that runs/hooks very well.
Top Bottom
