Mar 15, 2011 #1 V vlzman Member Joined Mar 28, 2008 Messages 158 What kind of a brand would be best choice for race oriented stage motor? Rods are wide journal and are .020 over, mains are .010 over. thanks Veljo
Mar 16, 2011 #3 S Squid4life Well-Known Member Joined Jul 5, 2004 Messages 6,275 I keep checking this post praying for someone to answer you, I need to pick up some bearings too to start mocking everything up... Anyone?
Mar 16, 2011 #4 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 Contact TA Performance and they will fix you up with the correct bearings for your application.
Mar 17, 2011 #6 V vlzman Member Joined Mar 28, 2008 Messages 158 Nick Micale said: Contact TA Performance and they will fix you up with the correct bearings for your application. Click to expand... Last time I checked from them then they didn't have wide journal rod bearings .020 over
Mar 17, 2011 #7 O odell4o8 Member Joined Jun 9, 2001 Messages 867 bearings mike at full throttle sells king bearings. they still make 020 wide jurnal bearings, i bought clevittes from ohio crank shaft co, few years ago for a 020 under crank wide jurnal, good luck oc,
