Steve Wood
- Jul 18, 2001
Originally posted by REDS HOT AIR
when the blades break off the exaust wheel..
Hey, they become really efficient then! No back pressure and that exhaust really opens up!
Originally posted by quickt
. IMO what ever works for you then use it.
other words that has to do with valve overlap which is controled more by lobe seperation angle
so if you take a 206-206 cam with 114 lobe spread and then you take one with the same specks but ground with 110 degree lobe spread then you have more overlap and reversion
Originally posted by turbocharged87
Let's forget the cam thing for a second. Someone needs to help me tune another 1.5 sec's off my 10 sec. combo I supposedly have on my car. How many of you out there have a stock intercooler car running 10's ? Is it possible to run 10's with a stock intercooler, 15psi , pump gas and street tires? Any help would be great as not to waste money on a front mount or race fuel or slicks. Thanks in advance
Originally posted by 86brick
Woody, Dennis Hogan ran 10.97 on pump gas and alcohol a while back. He's a good friend of Geno's and Geno posted it in the Alky section a while back. I did a search and found it. The car had a PT52 turbo, V4, 50's, GN1 aluminum heads, 208/208 flat tappet cam, and he was running a 20deg timing chip with 22lbs of boost. If you'd like do a search on Dennis Hogan and I'm sure you'll find it I know of a certain silver T-type down in the Fort Lauderdale area that ran 11.30's @119mph with a 1.62 60' with 20lbs of boost on pump gas and alcohol and I'm sure blackshoebox (Alex) will get this car to run in the 10's with a better launch and a little bit more boost
With less blades was there less Drone:: Sorry had too..Originally posted by Steve Wood
