Best headgasket for SII
TurboTA3.8
You wont keep up the pace
What is the best headgasket you guys are using on a Stage II with aluminum heads? We're leaning towards using the Cometics, we have the Felpro 1026's now.
thanks,
george
Cometics by far. Locwires gave me trouble with the big bore and combustion chambers of the stage II heads. Plus with the cometics I can specify thickness to play with compression ratio or make up for a milled head. Priced about the same as a locwire set for normal thickness. On the high dollar pro 5.0 mustangs locally the Cometics are performing perfectly, versus the 5 or 6 pass copper gaskets they had been using. No down side to them. Still would not recommend on a stock block motor, I prefer the head gasket to be the "fuse" on those motors.
Greg Kring
9.05@150 street car
