best mods??
87blackbuick
planning on spending $2000-$3000 this winter what are the best mods for a stock car.
thanks for any info
Please don't just throw money at it.
Get the basics done (fuel system, cheap mods, etc)and get a scantool. After you are sure all is good, then you can start modding, and you will learn all about it on the way there. I think I learn something new each time I play with the tune/boost, including weather changes, etc. I'm just scratching the surface, I think.
Well, I'm a newbee modder myself, but my research (and I hope others will chime in and verify/correct me) concluded that the best starting mods, in no particular order are:
Scan Tool
upgraded Fuel Pump / Hotwire
Passenger Side Breather Bypass
K & N filter / Cold Air Kit
160 Thermostat
Adjustable Wastegate
Adjustable fuel Pressure Regulator
Aftermarket Boost Gauge
RJC Power Plate
Spring Cleaning
I would do the fuel system first.Then a scanmaster at the least.Then a chip.Then a good cold air intake.Then exhaust.And when I say fuel system I mean fuel pump,hotwire kit,adj.fuel pressure regulator and definitely a fp guage that you can see while driving.Those are very important peices.Oh and a good boost guage.
Yup - and don't forget the front frame braces from an Olds or Chevy G-body. One of the best & cheapest mods going.
Go slowly and learn your car. You'll be a lot happier with the results.
hey swt86 these framebraces that you are talking about are these that go from the inner fender to the radiator support..
is this correct...just about 1 1/2' - 2' long....
is this it:confused:
the braces go from the fender to the front really short like corner braces top and bottom
SMC alky kit!!! Best bang for you buck mod bar none. Just make sure you take care of all the basics first!
