best size tire for vector 8.5 wheels on rear
lib87t
GAME OVER
Something in a Drag Radial or like ET Street with NO Rubbing. I dont want to run spacers either. Car has airbags and stock rear coil springs. Also Im running 235/60/15s on the front and have run 225/60s up front. I dont want a crazy raked look, a hair higher isnt bad tho
The frame won't be the problem. It will be close to the wheel well no matter what. A 295/55 or 275/60 will fit.
Hoosier DR 275 60 15 on 8.5 vectors rubbed my outer fender. No spacer is needed with these wheels. You'll need to roll the lips.
had my Vectors widened 1" on the back. Pulls the tire away from the fender lip.
no pics on the car yet. Weldcraft Wheels did it. I can't remember exactly what it cost. Couple hundred for the pair I think.
275/50-15 should fit fine. Less chance of rubbing if your rear is centered and if you run airbags.
Yup will need air bags to complete the 70/80's broncho billy "look" :p
Umm...no.
The bags keep the unrolled lips and fender trim from grazing the tires on a hard launch.
The bags are not to achieve the Gabriel "Hi-Jacker" air shock look.
I don't run airbags and I don't rub my untrimmed lips on a 1.51 launch with these tires. 26 10 15 on the vectors. I like those 295 55 15's, that will be my next tire!!!
I run 275/50/15 Nitto DRs and I am dropped 2" and have no rubbing at all. They are on stock Monte SS wheels.
