Been doing some reading....would like to replace my stock suspension components but as I have learned that's going to run me easily north of $1500.
As of now I have the stock 15X7 rims with the stock size 215/65 tire, however the tires are the Michelin Exalto's which are not even a year old. I also have the rear trunk braces and the jounce braces. As far as i know the reat of the suspension is bone stock.
At first I thought maybe polyurethane bushings in the stock control arms would be the best way to go since I've read worn bushings will contribute to a mushy ride....but I believe I read polyurethanes are not as great as everyone thinks? Any truth to this? And that urethane bushings are better? (sorry not sure here..:redface
My goal is to make the car more stable while cornering instead of having a ton of body roll. But at the same time not spend a ton in doing so if at all possible.
What about a bigger front and rear sway bar...would that yield me the best bang for the buck for the curves?
