SignUp Now!Good stuff.I just did all my trim with krylon satin. Bezels, grill, and all the window trim. I think it looks great.
I use SEM Trim Black 39143 on my GN. It works just great. All you need to do is sand the item with 400 grit sandpaper and apply three thin coats, with 10 minutes between coats. I just did the T-Top side trims, the headlight rings, the door edge guard, and both rear tail light trim pieces that I got from Intercooled88s,(Bob). I was so happy at how great they look, matches the rest of the stock black trim, spot on. Costs $8.79 at an auto paint store, but to me well worth it. The Krylon semi flat is nice too, but not quite the right semi flat, and only if you look real hard you can spot the difference between them. I've read that the SEM paint is slightly harder paint when dried.
Bruce '87 Grand National
I plan on painting all of the same things that Bruce Urie painted. What is the finish on the SEM trim paint?
it's satin black. What 49-blues said is correct. Maybe i forgot to say satin in my original post. I was thinking of semi-flat because i've used the krylon on my vettes a lot. It's sem trim black, satin, 39143
their website is very informative: sem products - home site
bruce '87 grand national
Bruce, do you wipe the part down with something before spraying after sanding?
I really like Krylon's Fusion line. Satin Black is what you'll want.
Ditto on the SEM. I recently redid all the exterior pieces for an '87 GN I'm restoring.
