Looking for input on the best way to upgrade the rearend in my T-type.
8.5 posi rear completely stock is the current setup. TH-400 with a brake Also getting a new driveshaft for 1350 ujoints.
Yoke in the differential for 1350 ujoints? where to get?
What should I get to upgrade the rearend?
Best axle?
Spool?
Locking diff?
I want to replace everything and am looking for a good setup for 1.6-1.5 short times.
So post and help me spend my money.
 Also getting a new driveshaft for 1350 ujoints.Yoke in the differential for 1350 ujoints? where to get?
Best axle?
Spool?
Locking diff?
		 . In fact i didnt even need to re-shim with the Eaton. The fit was the same with the stock shims in the stock spots. This could be completed in an hour easily if the bolt is not broken. The 31 spline axles were run in the 1.30's for 60's. A spool and 33's would be good into the mid to high 1.20's.
