best way to Lock-up?
Hi Guys,
Been a while since I posted. I changed my TCC solenoid (believed to be sticking) and added a deep alum pan with a 700 filter.
Now I want to wire it up to lock up in 4th like the one wire diagram linked above in ths thread. I can source the 8627332 switch through GM, but will take around 10 working days to get up to Canada.
Can I use the TCI N/O two terminal pres. switch that came in TCI's kit?
How do I wire this in?
Thanks for any help.
Hi Guys,
Good Diagram here.>> 700-r4 / 4L60 converter lock up wire diagram :biggrin:
O.K. :smile:
I'll follow this wiring diagram and ground the black wire to one of the valve body bolts.
Before I put the pan and fluid back, I'll put the key ignition on, my L.E.D. will turn on, will I hear the TCC solenoid click on? Put the brakes on and the solenoid will click off?
Obviously wired through the brake switch.
O.K. :smile:
If you bypassed the 4th Pressure Switch it would click. TCC Solenoid will only receive 12V when in 4th gear & 4th Pr. Switch completes the circuit.
Use a Test Light or Volt/Ohm meter to make sure you have a Ground on the Vbody bolt. If not run a Ground wire from Trans to frame/engine etc..
