BIG PARTS LIST, more parts added and parting Race car body
Condition of Aeromotive pump? Age? Pics?
Conrad
driveshaft needed
hey bob, left you a phone message today for a driveshaft for 8.5 rear. tried to send email on your 2 addressess but i am quite stupid when it comes to computers. i am in upstate new york and can pick shaft up. thank you.
Hey Bob I sent you a PM earlier this week. We still good to go on the Header Panel and Driver Fender or did I putz around too long?
Intercooled88s said:
New Parts added to list June 14th. 2006
Cottons Front mount with pipes $550
Aermotive Fuel pump $150
New UB machine Front upper control arms(ball joints were installed and removed but were never mounted on a car) $80
Fiberglass front bumper $100
Fiberglass pin on hood Taking offers , pick up only
Hurst Floor shifter(Pistol grip Quarter stick for 200 4r) $100
Richmond 3.73 gears $140
Rear seat brace kit $25
T-type fenders with GNX louvers $150 for both
Nitrous set up made by NOS specifically for the 86-87 GN. Comes with upper plenum modified by NOS with 6 nossles, bottle, solinoids, braded lines, switch
etc. $200
8.5 NON Posi rearend 3.42 gears complete drum to drum with driveshaft $500
Vacuum brake set up complete with pedal $65
Rear spoiler(aftermarket GN) $100 all 3 pieces
New Caspers Coolant Hi-Lo Fan switch $20
AC delete Bracket with pulley $20
87 Grill $100
85 Grill $40
87 Engine 69k long block $1100
87 Engine 46k complete(Engine harness, all sensors, all accessorys, intercooler ect) $2400
BRF tranny $500
8.5 rearend housing for GN $300
Stearing column from 87 GN $150
Dash Pad(grey) $100
Power Master 69k $200
87 Power seat track $85
Lock set (3 locks) $60
86-87 tranny dip stick tube $40
Locking T-tops $150
T-top boot shaped plates that the t-tops lay on $50
GN console $150
Dash harness $70
GN Concert sound 2 lower door panels $120
GN passenger seat in good condition $80
87 Grey passenger seat in good condition $80
Tail lights $100 a set
Quarter glass $100 a set
power trunk mechinism $20
Trunk Lid blackout trim piece $35
Blue console lid $30
New T-type emblems $20 each
T-type horn center $30 no ring
T horn center $30 no ring
T-type header panel $150
85 Turbo to intake adaptor $40
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC compressor(86-87 AC compressor) $60
AC lines(86-87 or 84-85) $45
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $30
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $70
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Belt tensioner(86-87) $70
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $60
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
CONVERSION (84/85(Hot Air) to 86/87(Intercooled) conversion parts(all the original GN parts you need to convert
over from 85
to 87) $1400)
Crankshaft(Turbo crank will need to be turned to .010/.010) $250
Crankshaft(Turbo crank .020/.020, never run in engine) $150
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $45
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $45 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Lower intake manifold)$130
Intake manifold(86-87 Upper intake manifold)$30
Intake manifold(84-85 GN intake) $40
Intercooler $60
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(Engine frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $60
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $30
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody with TPS,IAC motor,vacuum manifold) $60
Throttle bracket(86-87 Throttle bracket) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Turbo(86-87 Turbo can be used as a core) $50
Valve covers (84-85) $30
Valve covers (86-87) $35
Valve cover oil filler tube(86-87 tube and cap) $30
Wire harness(84-85 engine wire harness) $100
Wire harness(86-87 engine wire harness) $200
INTERIOR:
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Console(85-87 GN) $140
Console(grey and shifter on the floor)$100
Console shifter plate(Plate on console that goes around the shifter)$30
Console(half console for Limited)(grey and shifter on column)$100
Dash pad no cracks(grey or Maroon) $100
Dash pad(Maroon dash pad, no cracks) $100
Door panels(87 T-type upper door panels) $60
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $50
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN seats front and rear in great condition) $500
Seats(87 GN Front bucket seats need recovering) $150
Seat belt set(grey)(10 pieces) $60
Shifter $35(84-87 GN, needs T handle)
Steering column(grey and shifter on the floor)$120
Steering column(grey and shifter on the Column) $100
Steering wheel (Grey and in excellent condition(not redyed or recovered) with horn ring) $300
Steering wheel(good to have recovered) $40
Surround(Gauge surround) $35
Surround(radio surround) $25
Third brake light(Grey, red Maroon, or blue Third brake light)$25 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, or grey , all 6 pieces $100
Visor(Nice blue passenger visor with lighted mirror) $25
Body Parts:
Blackout door handles $15 for both
Blackout wheel well trim $40 each
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$100
Bumper reinforcement(Alum. rear bumper reinforcement) $80
Grill (86 T-type grill) $70
Grill(85 GN grill) $40
Grill (87 chrome grill painted black) $40
Grill Emblem(85-87 T-type grill emblem) $20
Grill emblem(87 , says "Buick") $20
Fenders(84-87 GN fenders(GM)) $80 each
Header Panel(84-87 T-type header panel) $150
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $100 for both sides
Tail lights with blackout trim $100
Tail lights with chrome trim $70
T-tops(86-87 GN locking T-tops) $150 a set
T-tops(84-85 GN NON Key locking T-tops) $150 a set
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Mirror(Passenger remote mirror) $40
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Driveshaft for 8.5 rearend $50
Fuel pump hanger/sender $50
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Hydrobooster brakes $100
PowerMaster to firewall adaptor(bracket) $30
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Transmission(BQ coded GN transmission 48k) $300
Transmission(BRF coded tranny) $500
Tranny cooler $20
Transmission oil pan(Stock 200 4r tranny pan) $25
Transmission(BRF tranny , missing valvebody and oil pan) $100
windshield wiper assembly $15
Wheels(86-87 T-type wheels for all 4 in good condition)$250 or 1 For $90
Wheels(86-87 GN wheels)good for cores all 4 for $100
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 746 9668 I rarely check my voice mail so if you call and don't get me try again later. E mail is quickest to contact me.
How much for a clean driver side door ship to 11236
My GN just got hit in the front in my apt. complex. I need some front pieces from you. I need the front pass. bumper support. (This is the piece that pushes in like a shock correct?) I also need the pass. side filler panel. Header panel if you have it. My need other things also, but I'll start rebuilding first with these pieces. Thanks.
Jason
Door Panels
Still waiting for your paypal address to pay for the door panels.
Let me know.
Thanks,
oil pan
sent u email about 20 bolt oil pan for a :smile: 87 gn motor
thanks regalwe4 kevin
etc. $200
87 Grill $100
85 Grill $40
BRF tranny $500
Dash Pad(grey) $100
Locking T-tops $150
GN console $150
Dash harness $70
ENGINE PARTS:
Alt.(86-87) $60
Alt.(84-85) $30
over from 85
to 87) $1400)
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Intercooler $60
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Timing cover $35
INTERIOR:
Map light $20
Body Parts:
Misc:
Tranny cooler $20
What shape are the T wheels in? Center caps included?
Do you have a blue steering wheel ring? How about a blue shifter handle?
I also need 1 chrome headlight ring and an OE turbo shield.
I need the front window trim (under the wiper arms) in black...got one in good shape?
