Biggest Streetable turbo with 3400 stall and 50lb injectors
oehm
What would be the biggest street strip turbo one could run with a 3400 9/11, and 50lb injectors? Is a 3400 stall enough for a
te-45a?
Hmm, see my sig but don't go overboard on boost or you'll run out of fuel.... TE-45a and T64E are the same I believe.... different manufacturers.
I say go with the biggin and upgrade your injectors.
I run a 45a q-trim with a\c 34-3500 stall, 55injs. Works great. I think Chris Mcdade on here used to run a 66q-trim and 50# and 3400a\c conv.
Don't let the big hair dryer scare you. And, don't let other board members say it's not streetable. It is. Even if it slows your spool a tad, the top end rush is awsome! You'll be passing them once the boost hits. :D
Originally posted by oehm
What would be the biggest street strip turbo one could run with a 3400 9/11, and 50lb injectors? Is a 3400 stall enough for a te-45a?
45a will do really well with 72 PPH injectors.
If your into the running injectors static is good enough then you can get by with less, but don't be surprised when you start popping headgaskets.
What people constantly ignore about injectors is Accleration Enrichment, ie Pump Shot. Again, you can get by with smaller, but cars just run so much better with properly tuned large injectors.
I'm running a t70 BB with a 3000 stall conveter. Runs great and spool like a mother.
Check out the GT67 =D... or a TE-45A from John Craig, those work great on the 3400 stalls I hear. Just get some 72# injectors if you're thinking about 55's.... same price =/. Might want to invest in a double pumper.
