Whats the biggest tire I can run without rubbing on the inside,and frame???? I'll be running a 15x8.5 inch rim, looking to run some mt drag radials just need to know how big of a tire to get........ any help would be great!! Thanks
The WIDEST tire you can run without rubbing the frame is a MT 275/50/15 DR. The tire is mounted on a stock 7" GN rim. You can see by the pic, that the distance between the tire and frame ain't much.
Well right now I have 275/50/15 bfg t/a on a 15x8.5 and it fits with just alittle space between the frame, but I dont know what the backspacing is. I just want to put m/t radials on the same rim, and not have any problems.
Here are pics showing the room between the frame and tire using some 15"x10" with a rear spacing of 4.50" and some 275-60-15 tires...I had to put a 1/4" spacer on the left side as the rear axle is not perfectly centered under the car (by the way, it rarely is... ). If you're using some 15"x8" wheels, then, the same tires as mine can be used with on a wheel that has 3.5" rear spacing...Hope this helps...
