stovebolt 34
- Mar 9, 2012
Need some opinions , comments , corrections , scoldings or whatever . Just replaced the 692 servo with a billet servo . It appears to be a brand new unused Sonnax . Used my stock servo pin with the stock inner piston , cushion spring , cushion spring retainer and stock return spring . They tell you to remove the seal from the inner piston and discard . I question why you would remove the inner piston seal as it appears to be nothing but a spacer now . Like I said it appears to be a Sonnax but but I got it off "Flea Bay ". The machining appears to be really good . The outer piston and cover seem to be close tolerance .
What gets me is it uses pfte ( teflon ) ? seals on the piston . One solid and one scarf cut . I always thought lip seals would be better ???
Bottom line > > > It doesn't shift as hard as my 692 . Why ? ? ? ? ?
Thanks for any comments .
