Black smoke
jacksorroche
I got the engine started!! Thanks to all
Now the engine runs very very rough and there is a ton of black and white smoke. I think that it is running very rich, but am unsure how to lean it out. I also did a diagnostic and I get the 12 code, then the engine light goes out and the fuel relay starts clicking again. :confused: :confused:
My setup is as follows:
TE44 turbo
MotoTron 60# injectors
Stock IC (Until I get the streach IC)
30 over 109 block
62mm Throttle body
TH 3" down pipe
I appriciate all help.
I think you will need a chip burnt for the translator. Someone please verify.
You can't run a stock chip with # 60 injectors. Get a Turbotweak or extender and you'll be set. :)
No special chip is required for the translator set up.
Talk to Eric@turbotweak, he will set you up with a good burn, because you definately need a chip for injectors that are that big :eek: . You can get a hold of him at www.turbotweak.com .
,Dan
