Bleeding brakes taking forever!!! ???
VADER
Little engine that could
Hi, I replaced some vacuum brake parts, booster, master cylinder, braided front lines, rotors, pads. I had to reflare the front driver side fitting to the flex line, and used new copper washers on the banjo fittings. I have been bleeding this thing for what seems like forever. I have gone through 2 qts, and 2 pints of fluid, and IM still getting lots of bubbles. I have retightened everything I took apart. The master cylinder was dripping a little, so I tightened it more and it stopped. I had a steel one, and now its aluminum. I had trouble bleeding all the wheels, but figured it was due to cracking it all open. I stopped bleeding the others when I got one or 2 full pedal depressions without bubbles. I do notice that when the pedal is depressed, that bubbles initially come out, then stop, and start again when the pedal is right at the bottom. Really weird. Im thinking I may have reflared wrong, but this shouldnt affect the other wheels, or the steel prop valve that I ignored. I have bled them before without taking it apart, and it was ok then. I also did bench bleed the master cylinder. :confused:
If a brake part takes in air, will it also leak fluid? I can probably find it that way. Im almost afraid to tighten things more as if they will strip, or crush.
I know it's frustrating Danny. You "can" reuse clean fluid and since you've gone through as much as you have, it's undoubtedly clean now. Do a gravity bleed. Just do one wheel at a time, farthest wheel away, then forward in sequence. It's a good Saturday job that will take a few hours. Invariably you get bubbles when you pedal bleed. Also wrap all your bleeders with teflon tape on the threads so they aren't loose when opening/closing. The rears tend to be most loose.
One question: When you depress the pedal, look at the master cylinder with the lid off. Does fluid spurt upward or does it just make tiny bubbles on the surface?
I have a really off the wall question. Did you bench bleed the master cylinder?
Hey John, how are you doing?
When the pedal is depressed the fluid goes up, if you press too fast it will go right over the side. I still have to clean that up :)
Yes, I did bench bleed the master cylinder.
What I find weird is that when I am bleeding it, after the pedal is depressed and I tighten the bleeders, bubbles still come out slowly. I dont fully tighten them, but I dont think that should happen. I almost think that when the pedal is pulled up, its taking in air, and Im repeating that over & over. Bleeders dont wear out do they? I think you cant teflon tape the inside of them, but maybe I can on the outside.
You have an internal leak in your master cylinder. The spurt over the side is a dead giveaway. Check out this article: http://www.babcox.com/editorial/bf/bf60133.htm
That article helped me more than anything. Basically you need to return your master cylinder and get a new one. I got a new NAPA master cylinder for a 87 Regal with a 307 engine, about $75. It ended up being cast iron but I went through 2 remans before buying this one. The reman does not replace the internal valve; it's non-servicable. A new master cylinder will give you a pedal you can hold an easy 12 psi of boost without making this face :mad: .
All the teflon tape does is seal the threads around the bleeders so air doesn't get sucked back in past them into the calipers/wheel cylinders. It is good to do.
Update, recvd new master cylinder, bench bled, installed, & system bled easily, about 15 pumps rear (to clean out dirty fluid), and about 5-8 for the front. No more bubbles. Sounds like prop valve occasionally makes a noise, but that might be normal. I'll drive tomorrow to see how it holds up.
