MY Extender Extreme has a parameter called block learn correction where I can shift my entire fuel map to the left or right. It's as simple as it gets and again closed loop. I use this feature to add 20% fuel and I get the other 10% with the base fuel knob on my Translator Plus Then I have a knob on my Translator Plus to turn for WOT fuel. Your limiting factor is your ability to move fuel. It will be interesting to see how far you can go. When I first experimented with E 85,I used 100% E85 so I was only able to run 16 LBS of boost safely without upping the fuel pressure. I already had enough fuel supply capability,so all I needed was 120s to finish the job. I regret not experimenting with higher fuel pressure with my 72s. I'm hopeful that you will be able to go farther with a 50/50 mix and experience the faster spool that E85 produces.I do understand what ur saying. The XFI has lots more bells and whistles than my GEN2 translator![]()
