ericmccann
- Jun 6, 2008
The biggest problem I'm having right now is determining what is and what is not stock on this motor.
How much do you want for the 36# injectors?
Oh, and I have an Accufab FP regulator, not installed. Sorry I forgot to mention that. But, that's probably exactly one of the 'must-have' components.
The Wastegate is adjustable. You can see by looking here: IMG_8805 on Flickr - Photo Sharing!
I also have the electronic (I have a digital dash) boost gauges connected and functioning. I also have an Autometer boost/vac gauge mounted on an accessory gauge mount on the drivers side pillar. The electronic gauge only saw yellow, and I was watching the autometer boost/vac gauge when this happened and it only read 10#'s.
After just now looking at the other gauges (all Stewart Warner gauges), those were oil pressure, water temperature, and oil temperature.
I did find wiring for these gauges under the radio console. I suspect that this car had been beaten up a bit by one of the two PO's. I suspect that it's the first PO who bought the car new in 1987 and owned it up until sometime in early 2006.
Thank you for not taking offense to my previous message. I'm glad that we're on the same page. Please also understand that I DO appreciate your kind and well-thought advice. Your mechanical knowledge of these engines will forever surpass mine, but I just felt like I needed to make it clear where I was comoing from in terms of this car as a project.
I'm going to buy an intake plate, as you suggested, I'm also going to have to buy a scanmaster, unfortunately. Maybe I should move my Innovate Morotsports Wideband O2 LC-1 assembly over to the GN from one of my other Italian cars?
Thoughts?
Best,
Eric McCann
Thoughts?
Best,
Eric McCann
